CPU Too Hot?
Go to solution Solved by FloRolf,
My 2600k got up to 95°C at times. I wouldn't run it long at those Temps though :P
Try to keep it below 80. So just try to run a game and see what it does. If it goes insanely high, just buy a $20 cooler like the Hyper 212
My i7 2600k paired with a 650 psu from Corsair runs at around 40 degrees Celsius while nothing is going on, which I know is fine. It jumps up to 60 degrees when I'm playing CS:GO, and I'm wondering if it will be okay to play games like battlefield 1 or rainbow six siege. Should I change my case for better air flow or get a new heatsink?
https://linustechtips.com/topic/913492-cpu-too-hot/
Are you using the stock intel heatsink?
60°C is fine.
https://linustechtips.com/topic/913492-cpu-too-hot/#findComment-11212877
Play them and you'll see
Desktop benching:
https://linustechtips.com/topic/913492-cpu-too-hot/#findComment-11212883
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/913492-cpu-too-hot/#findComment-11212908
