Help with basic bash scipting
Solved by Willowwizard,
For bash scripting you can use a cheatsheet (for example, I use this one) to learn about the programmatic elements (e.g. program flow elements like if, for, while, etc.).
and as for other functions like copying (cp) and moving (mv), as tikker said, you can use the man command to view it's documentation.
Here's an example for the first script, anyway:
#!/usr/bin/bash if [ ! -f test ]; then # If file "test" does not exist, then echo "" > test # Create (overwrite if it exists) file "test" with blank contents else # If file "test" does exist then echo "" > test2 # Create (overwrite if it exists) file "test2" with blank contents fi # End of if statement cp test temp # Copy file "test" into "temp" (overwriting if it exists) mv test ./storage/.conf # Move "test" into storage/.conf/ (storage/.conf must exist beforehand) mv temp ./storage/.conf # Move "temp" into storage/.conf/ (storage/.conf must exist beforehand)
Edit: You can learn about user/group/password management here
