just got an evga clc 280 on my delidded 8700k. 4.7ghz across all cores on 1.248v with an ambient temp of 27c, i get an idle of 40-42c, and during cinebench i get an avg of 62c, and avg 70c for aida64 stress test. Just wondering if these temps seem normal, on hwinfo all cores are roughly the same temp so i dont think theres any dust between the die and ihs, put just enough liquid metal, no pooling whatsoever, both on the ihs and die sides, i also have a copper custom ihs.
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/913078-cpu-temps/
Looks good.  Push it harder.  You won't break it.
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/913078-cpu-temps/#findComment-11208948
1.42v 5.1ghz in games at 30-32% load its hovering at like 68-70degrees, is the 8700k just that hot even with delid? it looks too high
https://linustechtips.com/topic/913078-cpu-temps/#findComment-11209062
hitting 75-77c in cinebench at 1.408v. does this look normal? i think its a bit high, also when i cleaned my copper ihs today, and reapplied liquid metal, the surface touching the cpu die felt rough instead of smooth when it was brand new.
https://linustechtips.com/topic/913078-cpu-temps/#findComment-11209196
