Hi know this is not the right place to ask this but i need help on this html css project
i want to obtain results like this on my website http://tastybistro.com/menus/
with inpage navigation bar adn different sections ,
any time tutorial link or hint will help me , i tried searching but couldn't find anything  in html or css solution .
i want a solution in html and css only.
https://linustechtips.com/topic/913023-help-on-project/
Just inspect element on that site and figure it out. That's the way I've always learned more in terms of programming.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/913023-help-on-project/#findComment-11208396
Show what you've tried so far. Its hard to help without knowing exactly what you are trying to do and how much you do and don't understand about html and css.
Web Developer and Java contractor
https://linustechtips.com/topic/913023-help-on-project/#findComment-11208856
Why do you not want to use JavaScript for that?
After searching some time I found something, you could use the "checkbox-hack": https://jsfiddle.net/t2t3gor1/5/
I got the idea from here https://stackoverflow.com/questions/13630229/can-i-have-an-onclick-effect-in-css/32721572#32721572
for(var i = 0; i<= 1/0; i++) {
	alert("Look, i am like while(true){}");
1/0 != Error; 1/0 == ∞
https://linustechtips.com/topic/913023-help-on-project/#findComment-11211080
7 minutes ago, M.Yurizaki said:
[snip]
The "hack" is also known as "pure CSS tabs"
(this isn't my codepen, but it'll get you want you want. Adjust to taste)
This is impressive. I was about to claim it couldn't be done without JS, glad I read this first...
For the OP - I would still go down the JS route. Especially is you use something like bootstrap as jincio suggested, it means you don't have to write any of the JS yourself. Normally it's just a case of adding one or maybe two script tags to your DOM.
https://linustechtips.com/topic/913023-help-on-project/#findComment-11211138
There's a lot of nice things you can do with pure CSS that at first glance at the problem you'd think it must have JS.
I make it a challenge when I want to goof around with single pages that present something to do it purely in CSS/HTML.
https://linustechtips.com/topic/913023-help-on-project/#findComment-11211223
The more CSS based stuff you do the lighter your website becomes. Web pages nowadays are libraries on top of libraries.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/913023-help-on-project/#findComment-11217655
