Is the GPU overclocked?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
This ^^^
Also try different cables and ports.
If it is overclocked, bring it back down to stock settings.
If its not [multiple] really loose cables, then thats some severe artifacting if its not bad drivers (update them if you can) or that your overclocking the card. If that is the case you'd need a new GPU that one is pretty toast.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
2 minutes ago, theinno3 said:
So its 100% graphics card? if so i will just order new one
We don't know if it's the GPU specifically, which is why we need to rule out displays, cables, and ports.
Also, what model GPU do you have? As mentioned by @suchamoneypit, update drivers too.
i have gtx 970 the original one, all cables must be good cause i tried different ones.
Did you try different ports as well?
yes i tried hdmi instead of dvi and the displayport
Has your card been thermally abused at any point in its lifetime?
Never cleaned my pc is full of dust, also it sometimes get stuck in bootloop, and i got the error code something with "video" but could not read it all, the screen is ok at startup but when it starts loading to windows it gets fucked. if im lucky i can load it into windows or else its just boots, turns off and boots again.
Clean everything. Blow out all the dust, replace thermal compound.
on cpu or gpu? aleready ordered graphics card just wonder if it can be problem with anything else because i need computer fast to get work done... what other possible things can be broken if not the gpu for this to accur ?
Displays and/or cables.
I would say clean the GPU thoroughly and then determine if you actually need a new card.
but the display or cables wont stop the computer from booting right? It takes like 25-30 tries for me to boot the computer up...
Test your PSU.
how can i do that without any tools?
If you have a friend that will let you test their hardware, that'll work
Thanks for all the help i will try that and wait for graphics card, will update after i get the graphics card hopefully tomorrow :)
Looks like its ruined. Same happened to one of my 660ti years ago. Even to a igpu for my laptop. Its donso.
@Crunchy Dragon So i just turned the computer randomly on today, i had removed the graphics card set it in again and everything works like a charm, i checked the error logs for the blue screen it was this one 0x00000116 VIDEO_TDR_ ERROR, so what do you think was the fault with it since it randomly works again? I aleready ordered new card tho, is this one safe to sell (the old one) ? Temperature with furmark doesint go over 62c i cant think this is a heating issue...
  • CPU: I5 8600K at 4.9 GHZ
  • GPU: EVGA GeForce GTX 1070 TI SC
  • Motherboard: Asrock Z370 Pro4 ATX
  • RAM: 8GBx2 DDR4/3000MHz ADATA XPG Z1
  • PSU: Corsair CX750M 750 Watts
  • Storage: 2X256GB WD Black SSD & 2TB HDD
  • Case: IN WIN 101
1 minute ago, ScytheTrain said:
well i reset the graphics card and it works again, can i use the single graphics card on the second pcie slot?
