I had a wd blue laying around from my old computer.It was 320GB so i installed it into my computer.After booting it worked then after 45 minutes with skype running it randomly changed to a black screen and rebooted.It booted again and i shut it off.What caused the restart?
https://linustechtips.com/topic/912894-restarted-after-installing-second-hard-drive/
Depends, look at system logs.
   / | / /__  _________/ / /_____ _/ (_) /___  __
  /  |/ / _ \/ ___/ __  / __/ __ `/ / / __/ / / /
 / /|  /  __/ /  / /_/ / /_/ /_/ / / / /_/ /_/ /
/_/ |_/\___/_/   \__,_/\__/\__,_/_/_/\__/\__, /
                                        /____/
Hi, 「Neͥrdͣtͫality」noice to meet you... :3
Ok, if this anomaly only happens when you plug in the drive then sounds like a bad drive.
                                        /____/
