I just received an asus 990fx evo r2 and I matched the gold triangle and the notches in the socket all right and i also looked at the little plastic nubs that align with the bottom of the cpu, I built 3 computers this weak because all my friends got parts during black friday/cyber monday.  2 of them used fx 6300 and one was a 8320 in a gigabyte 990fx ud3.  I know how to install a cpu into a socket but on the side of the triangle there is something in the way and the other 3 corners of the cpu go down alright.  has anyone had this issue? the box came a little damaged but I don't know if that can affect the socket.
https://linustechtips.com/topic/91275-am3-socket-issue/
Are any pins bent?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/91275-am3-socket-issue/#findComment-1231672
if any of the pins are bent rma it, i once attempted to bend the pin back and place and it broke... ops. and cuz i broke it the warranty was voided so i couldn't rma it.... yeah just thought id say that.
CPU: AMD 760k @4ghz | Motherboard: MSI fm2-a55-e33 | RAM: G. skill 4gb @1833 | GPU: AMD HD 7850 | Case: Nzxt 210 Tempest (with glass window mod) | Storage: Adata 128gb ssd | PSU: Raidmax rx-530ss | Display: 720p crap | Cooling: CoolerMaster sickleflow 120 green x4 | Keyboard: crap | Mouse: Razer diamondback | Sound: logitech 2.1 speakers | Operating System: Windows 7 Ult | Battle.net: Voldras #1712
https://linustechtips.com/topic/91275-am3-socket-issue/#findComment-1232433
