Just bought a Gigabyte gtx960 OC used, and I noticed that the fans start very suddenly and loudly. As I understand, they only turn on when the temperature reaches a certain point, and this usually happens after a few minutes in a game.
The problem is, when they start up, they make a sudden "whoosh" sound. It's like they spin up higher, and then go back to normal. It all happens within second or so.
So I wanna ask - is this normal, or should I be worried?
https://linustechtips.com/topic/912463-gtx960-fan-question/
