Well my laptop Bluescreens and makes loud buzzing noises at the same time a lot now and i have to hold the power button and restard it but lately its gotten worse and i have to restart it a few times and i even had to restore to factory settings once. and when i restarted it some times it owuld make a loud buzzing sound for a second as windows booted up.
im assuming my harddrive is just messed and theres nothing i can do, but is there anything i can do to check or fix whats going on.
https://linustechtips.com/topic/91229-laptop-problems/
What does the bluescreen say? It reveals important info.
https://linustechtips.com/topic/91229-laptop-problems/#findComment-1231251
i do not have time to read it, i live with room mates and if it blue screens i have to shut it off right away because the noise is like a damn helicopter 6 feet above your head
Well if you don't/can't put in the effort to read it, how do you expect to get help?
https://linustechtips.com/topic/91229-laptop-problems/#findComment-1231281
if anyone has had anything similar happen, next time it happens ill be sure to snap a picture of it at least so i can read it from that. but is there any way as of right now to check out whats going on with it?
https://linustechtips.com/topic/91229-laptop-problems/#findComment-1231302
Not really. That bluescreen is the soruce of what you need to know. Most definitely harddrive related though.
https://linustechtips.com/topic/91229-laptop-problems/#findComment-1231359
