hi i am a first time builder and i was gonna get the ryzen 5 2400g but i might have needed a bios update so i was gonna go with the fx 8320e but someone told me it was old and so i want to go with the ryzen 5 1400 but i dont know if it also needs a bios update. does it?
https://linustechtips.com/topic/912223-pls-help/
As far as I know, there aren't any BIOS updates that can make any AM3 platform board compatible with Ryzen.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/912223-pls-help/#findComment-11200152
AMD will send you out a free "doner" CPU to get your system running. Details found here: https://www.pcgamer.com/amd-will-lend-you-an-older-processor-to-update-your-bios-to-support-a-ryzen-apu/
Also please make your topic title somewhat more descriptive please! This will allow other people with the same problem to find it in the future
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/912223-pls-help/#findComment-11200168
1 minute ago, ZcanKal said:
Bios update?  What about the fact that the socket is completely different.
That too.
https://linustechtips.com/topic/912223-pls-help/#findComment-11200178
Just now, advilnoscope said:
i dont understand
AMD have different platforms - much like Intel have different sockets. A FX 8320 is an old-gen AM3 chip. We are now on AM4 which has no cross compatibility support. The sockets do not match up - sorry! You will have to upgrade your motherboard too, and most OEM's will have the new BIOS software available so you will not need to update it. If you do, again referring to this: https://www.pcgamer.com/amd-will-lend-you-an-older-processor-to-update-your-bios-to-support-a-ryzen-apu/
https://linustechtips.com/topic/912223-pls-help/#findComment-11200186
3 hours ago, BlueChinchillaEatingDorito said:
That too.
i know they can send a cpu but i want something that will work out of the box
https://linustechtips.com/topic/912223-pls-help/#findComment-11200187
If you want that, then just get a 1400 and any motherboard from a reliable brand.  You may not need a BIOS update for the new 2400g, but in statistics like this, it's hard to beat 100%.
https://linustechtips.com/topic/912223-pls-help/#findComment-11200190
Then you will need a new Motherboard, compatible with Ryzen (I.E a AM4 Mobo)
If you get one that is generally recent, chances are you will get one with an updated BIOS. There, however, is no way to tell untill you take it out the box, unless the mobo was released after the CPU. ASUS motherboards (I belive) do offer CPU-less updating through EZUpdate (quoting @Himommies)
https://linustechtips.com/topic/912223-pls-help/#findComment-11200193
bu
is ther a cpu under 180 cad that will not need a bios update for sure
https://linustechtips.com/topic/912223-pls-help/#findComment-11200201
bu
I have no idea on their pricing but any RYZEN released last year (R3, R5, R7) would not need an update. However, would you mind telling us what motherboard you are using? Is it AM3 or AM4?
https://linustechtips.com/topic/912223-pls-help/#findComment-11200223
Then you would need a Gpu though and if he's buying a 2400g he probaly dosen't have one
My life
https://linustechtips.com/topic/912223-pls-help/#findComment-11200228
True. @advilnoscope - chances are with the newness of Ryzen APU's is that you will need to update the BIOS. If you have or are going to buy an ASUS mobo they can be upgraded CPU-less. If not you'll need to contact AMD about a dummy CPU to update. It is free and reasonably hassle-free. Make sure your happy with the update procedure for your Mobo (and make sure there is a Ryzen APU update) before buying
https://linustechtips.com/topic/912223-pls-help/#findComment-11200247
asus mobo's can be upgraded cpu less
https://linustechtips.com/topic/912223-pls-help/#findComment-11200255
