Id recently gained a paperweight of a sigma 17-50 due to water damage which just so happened to be the only standard zoom in my kit so i need to find a replacement. Im currently looking at the 18-35 for its superior build quality and ease of waterproofing since the focus ring doesn't turn when af is used and the zooming is internal. I also do an astounding number of night time event shoots so the fast constant apperture would be magical. I dont really care for optical stabilisation as a faster shutter would be more beneficial since my night subjects are somewhat fast moving. My only concerns are if the oens would get in the way of the popup flash and how able the lens is at taking a battering. Becuase I basically take all styles of photos, some of which require rather sketchy methods.
Are there any other similar options that fit my bill or is the sigma simply the best for my needs?
And no i wont be moving to full frame for many years if not at all because aparrently my 80d is slightly better at dr than the 6d ii so there really is no benefit unless if i got 5d iv which at that point id rather buy a car.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/912216-lens-purchasing-help/
1 minute ago, ars3n1k said:
Most of the large name YouTuber's swear by the 18-35 for most of their videos in every day use.
Jonathan Morrison
JayzTwoCents
to name a couple.
I'd say it's a wonderful pickup (though no personal experience myself)
Yes I've heard but theyre not applying it to a low light event shoot, which I'm finding difficult to locate details about with regards to the performance of the lens. Most the internet reviews are daytime reviews which really dont show the expected ability of the lens.
Desktop
LAPTOP
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200100
What camera are you attaching it to? I'd say with it's f/1.8 aperture you'd be fine no matter what.
Shot with an a6500 and according to the description, ISO was kept low at 2-500
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200110
I will be using an 80D, and thank you for the video link, somehow i couldnt find any reviews like such.
Desktop
LAPTOP
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200114
No probs. Not necessarily a review, but there's some good looking shots in there.
With proper exposure and ISO control from what I've heard, it'll handle whatever you throw at it
There's also this guy. 5:35 into the video shows off the auto focusing.
Also at the end there's some nice picture shots shown in a night time setting as well
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200137
why would the lens get in the way of the pop up flash? what exactly do you mean?
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200170
With some lenses when i fire the flash the barrel gets into the way of the light leaving a dark semicircle silhouette in the final image.
Desktop
LAPTOP
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200185
thats not something Ive experienced or heard of before and tbh given the prevalence of hate against most pop up flashes, I dont think youd be able to know if that is an issue unless you tried it. But, the 17-50 is itself pretty huge for an APS-C lens, if that was the case when that was extended, its possible that is the case with the 18-35.
Why dont you get a  cheap yongnuo flash instead? its a much better option if you actually need to use flash than the built in.
https://linustechtips.com/topic/912216-lens-purchasing-help/#findComment-11200323
