Well i just recently got a Zalman LQ315 liquid cooler and in the instructions it tell me that i have to "connect fan cable into 4-pin CPU fan header" and "connect pump cable into a 3-pin fan header on motherboard"
I think you have them the wrong way around???
The fan is a PWM fan so it has to go into a 4-pin and think it like an air fan cooler heatsink it plugs into the 4-pin CPU fan header, and so the fan with the cooling kit that is on the rad is simular just located on the rad. and the other is just a power connection for the pump. not sure if other manufactures do it different, i though the pump would change speed, but maybe it doesn't on the Zalman.
hope this helps....
got to love Asus components
https://linustechtips.com/topic/9122-motherboard-help/#findComment-101900
