https://imgur.com/a/HQ8Ju
So, on a lot of, lets say shaddier sites (Streaming movies/anime mostly in my case) they have started to do these, I believe, embedded add's into the GUI/interface of there webpages.
Can I do anything to get ride of it? I use the normal adblock, its has the best features by far, such as whitelist YT channels, but especially the "block an add on screen, hover over it and click" feature helps a ton to make a site look better, BUT it doesn't work on these...again I believe, embedded add's, that they do now a days.
Thanks.
PS; Just tried Ublock Origin, while its probably a superior end-user experience, also slightly more features, it doesn't block these add's i'm referring too, nor does it have a good whitelist feature for youtube.
https://linustechtips.com/topic/911686-help-me-block-some-adds/
sorry to ask, but why not just ignore them? i have a site that also has these kinds of ads and i just ignore all of them
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/911686-help-me-block-some-adds/#findComment-11195235
Because it's difficult? also embarrassing if you see that at work and the boss is right behind you.
Desktop benching:
https://linustechtips.com/topic/911686-help-me-block-some-adds/#findComment-11195252
Can u PM me that website? I want to test if mine blocked them.
https://linustechtips.com/topic/911686-help-me-block-some-adds/#findComment-11195290
Any site thats free 3rd party hosting mirror site grey area thingy to avoid getting sued, includes some form of streaming has them.
At times going into adblock's "Click to block this on the site" feature, it works, but seems to not work for long, also its clunky to do that for all sites you visit.
https://linustechtips.com/topic/911686-help-me-block-some-adds/#findComment-11195795
I use Stevenblack hosts file + Opera built in ad blocker, i've never see those type of ads so not sure if it got blocked or i never enter any site that using them. xD
https://linustechtips.com/topic/911686-help-me-block-some-adds/#findComment-11195857
