Different Network Options? Help.
 Hey,
So Ive upgraded my PC and after doing that, My PCI slot WIFI network card, has stopped working...
So ive had to buy a new Wifi USB thingy. (https://www.amazon.ca/Adapter-600Mbps-Wireless-Antenna-Support/dp/B01M0Q51UI/ref=sr_1_2?ie=UTF8&qid=1522362578&sr=8-2&keywords=Wifi+usb)
I have no clue really why my old PCI network card stopped working, But I have now bought this one ^^^
Only paid 20$ didnt want to spend much.
Is it possible my speeds would be better (noticeable better) With a PCI Wifi Network card " Like I use to have"??
Wired
Wireless
https://linustechtips.com/topic/910913-different-network-options-help/
Wired > all
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
Woops, didn't answer the actual question lol.
Technically yes, PCIE would be better, but that would mostly be due to newer standards implemented. Your USB adapter should be good enough for basically anything you throw at it though.
1 hour ago, Foul said:
 Hey,
Wired
  Hide contents
Wireless
  Hide contents
It depends on a number of factors.  Lets assume your WiFi router is excellent and capable of far more throughput that you would ever need (1Gbps+).
Lets also assume your ISP serves up a similar speed, and that your router is a 1Gbps router.
if your WiFi adapter can support the signal from your router.  the limitation is the adapter itself.
USB 2.0 adapters will be slower than USB3.0 ones for example
That said.  a PCI-E card will be more stable in terms of signal.  but they too have limits.  a PCI-e 2.0 card has less bandwitdh available than a 3.0 card for example.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
Personally I wouldn't touch a USB WiFI adapter with a 30 foot pole. PCI express every day of the week and twice on Sunday. The AC chipset can get hot, when that happens I can stop those USB sticks from working right. While the PCI express card would have a heatsink on board normally to provide some cooling.
This helps alot, Thanks.
Random question, Is it possible my old PCI Network card no longer, Or is not "up to day" with my new Motherboard? It worked perfectly fine with my old board.
And now its not detecting it...
Old board.
https://www.msi.com/Motherboard/970-GAMING.html
New board
https://www.asrock.com/mb/AMD/AB350 Pro4/
It says my new board
  • 2 PCIe 3.0 x16, 4 PCIe 2.0 x1
But i swear ive tried 2 PCI slots, and nothing has worked, Not sure what one the 2.0 is....
Old board.
New board
PCI-e is backwards compatible.  so 2.0 will still work on 3.0 boards.  you just wont get the bandwidth improvements.
That said, if its old enough it could be a driver incompatibility where the drivers are no longer supported by your OS.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
