Mouse can move but not click after power outage
QuantumBit
Go to solution Solved by QuantumBit,
Well seems as if it was a problem in the Logitech settings... I opened it up and re-assigned the left mouse button to "left click" and it works
thanks for all the help though :)
So my power went out but quickly came back, and when my computer restarted, my mouse (Logitech G302) can move but not click. Ive tried different USB spots, and scanned for new drivers in device manager. I installed "SpeedyFixer" which I have the feeling is a sort of virus. Sadly it asked me to pay $6 to "fix all" problems, but thats a problem for later.
Any idea what I can do? I'm using a backup wireless mouse for now, which works in the meantime
I've tried the mouse on other computers, and it seems to work flawlessly. Any ideas?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
7 minutes ago, Ross Scarlet said:
Maybe the machine just needs a power cycle?
Nope :(
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Uninstall it in device manager, unplug it, plug it back in.
The geek himself.
Nope :(
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
there is no such software that can magically "fix all problems" - any software that makes such claims is very, VERY likely malware
This ^ Most such programs can do more harm than good.
Yea I was really doubtful, but I was so desperate for a fix, I did it. Nothing comes up when I googled it, so I didnt worry as much. MWB doesn't come up with anything though.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
8 minutes ago, QuantumBit said:
-snip-
can you test the mouse on a different computer ?
maybe the mouse got busted by the power outage or it just coincidently crapped out at exactly the same time that power outage happened.
if the mouse works fine on another computer then it could also be that some windows files got corrupted or something.
Problem is already solved :P
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
