Hi, having a bit of trouble with a recent PC I built and I felt this was the best place to go. Here is a link to my build: https://pcpartpicker.com/list/NfZqkd
Essentially my computer is working too hard for the tasks it’s doing. When I open OBS I get at least 50% usage (with no recording or streaming turned on). However, when I open stream LABs OBS (suppose to be less taxing for your cpu) it jumps up to 100%. This obviously doesn’t make sense, since I have an older pc with lower grade part and it works better than this.
 I’m getting a better radiator, to test if it thermal throttling, but I doubt it. I believe it has something to do with the motherboard or the CPU may be damaged.
If anyone has any ideas, I’m open for trying them. Thanks
https://linustechtips.com/topic/910685-help-with-computers%E2%80%99-cpu-usage/
