Has anyone heard of this, I downloaded a couple test files off of the net for testing my network speeds both 1 and 10GBE when first tested they worked fine with expected transfer speeds but a day later I'm only getting 25MB/s with these files but if I take another file I get expected speeds its almost like the files are getting corrupted or something if I take a file off of my system all is good I'm new to networking stuff but this seems off to me?
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/910123-strange-transfer-issues/
Windows file transfer over network can be wonky speed wise. Since how windows handles it fles they may be cached or just read from the drive directly, in which case the drive if busy will slow down the transfer speed.
If you want to exclude all those factors you'll need a dedicated drive on both ends for just testing. And use a big file to see where it settles down on, since it will start high and end on its normal speed after a while.
https://linustechtips.com/topic/910123-strange-transfer-issues/#findComment-11180678
Yeah I've been trying different things and have found that if I map drives to my desktop all files with the exception of the test files I mentioned have worked flawlessly on both my rigs at 10GBE speeds that really rocks I have my rigs peer to peer with my unRAID server with 2 mellanox cards, each rig has a 1 port and the NAS has a dual port there is just something wonky with those files I downloaded from the net
https://linustechtips.com/topic/910123-strange-transfer-issues/#findComment-11181133
