Rgb help
Solved by W-L,
20 minutes ago, Big BoNo said:I bought a bit fenix enso but to sync my rgb I need to have this weird 3pin header shown below I don’t have one on my motherboard and I’m wondering wear to buy an adapter
That case has a set of front LED's the use the 3pin addressable LED option on your motherboard. All you need to do is to disconnect it from the built in controller and install it over to your motherboard's RGB header.
