Hello,
So this is the Html
<ul id="theList">
  <div id="sdas">
    <div id="adsdsa">
I want to append a element to the last div, the ID's are random so I can't use that one.
How can I get the last div element using the ID of UL? I know this has something to do with siblings.
Back-end developer, electronics "hacker"
https://linustechtips.com/topic/909763-jquery-select-element-help/
13 minutes ago, HarryNyquist said:
$("#theList div div:last-child")
That should work unless I've not understood you properly.
https://api.jquery.com/last-child-selector/
Yea this seems to work, but I'm getting a really odd effect here, the element is added to the last div, ok thats what I want. But it's also added to the new element's div, and it's sub divs. What? :P
Going directly by the id of the last element (using console) it got added as I expected it to. Now if I do this on page load (I did div div as I do not have more than 1 div under it)
$("#theList div div").append("<p>Test</p>");
it adds it to all the divs under the
<ul id="theList">
  <div id="sdas">
    <div id="adsdsa">
      <li>
        <div>
        <!-- My added element -->
        </div>
        <div>
        </div>
      </li>
Why does it do this?
