There isn't much software and its really inaccurate, you would need to buy a voltage meter and plug in the computer to it and the other end into a power plug.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/909520-power-benchmarks/#findComment-11174120
If you have a corsair PSU you could use corsair link, but as Vandorlot already said that isn't as accurate.
I would also recoomend a wattage meter for your outlet. This is one I found from a quick amazon search https://www.amazon.com/P3-P4400-Electricity-Usage-Monitor/dp/B00009MDBU/ref=sr_1_2?ie=UTF8&qid=1522001023&sr=8-2&keywords=outlet+wattage+meter
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/909520-power-benchmarks/#findComment-11174127
13 minutes ago, KieranTHeBesT said:
Does anyone know a power benchmark I can do while playing games to see how much power my computers uses during games for free
HWInfo64 can get kind of close depending on the hardware in your system, but no software is gonna be accurate. When I plugged my Kill-A-Watt into the wall and plugged my PC Into it, I noticed that it would vary between the two as much as 30W at a time.
https://linustechtips.com/topic/909520-power-benchmarks/#findComment-11174153
k
Thanks a lot not sarcasm
um idk where it says the wattages
https://linustechtips.com/topic/909520-power-benchmarks/#findComment-11174172
CPU+SOC wattage.
Doesn't show wattage for your GPU or any other components.
https://linustechtips.com/topic/909520-power-benchmarks/#findComment-11174349
