Is it possible for me to buy a wifi set up for less than $100 and reach around 1000 ft away and get a strong signal? (I'm aware that it also depends on whats in the way and other signals around) There are a few trees in the way and a small 20 x 20 building made of wood. If so whats are the best options available? I've looked into directional antennas but don't know much about brands and what works best and also seen on some specs for routers and extenders they claim to go up to 2km? Any recommendations and info on prices would be helpful.
https://linustechtips.com/topic/909006-wifi-range-for-1000ft/
No. Not because the AP tech doesn't exist (it does), but rather you aren't going to get that range out of any consumer client devices.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/909006-wifi-range-for-1000ft/#findComment-11169570
Not at that price point or ability, there are long range AP for exterior use but for 1000ft your going to have to look into getting something like a bridge unit. That will require direct line of sight however so your going to need to mount it up high.
https://www.ubnt.com/unifi/unifi-ap-outdoor/
https://linustechtips.com/topic/909006-wifi-range-for-1000ft/#findComment-11169574
Im running point to point ubiquity nano beam dished to connect a friends house to my local network. The dished themselves do not broadcast a wifi network as they act as a bridge like @W-L said, but you can add a switch or another AP at the remote location. The set of dished run about $200. The best speeds will come from line of sight, but you can still get reasonable speeds with some obstructions.
https://linustechtips.com/topic/909006-wifi-range-for-1000ft/#findComment-11169578
Add an extra 0 to your budget and then maybe.
https://linustechtips.com/topic/909006-wifi-range-for-1000ft/#findComment-11169587
