Hey guys really need help. Wanting to upgrade to 16GB ram but I'm not sure how/where to start? Do i buy another 8GB stick or ? I am new to this so any help is appreciated, my specs are blow. Would it better to buy a 8GB Stick if so which one etc? TY in advance.
RAM
        Memory slots
            Total memory slots    2
            Used memory slots    2
            Free memory slots    0
        Memory
            Type    DDR3
            Size    8192 MBytes
            Channels #    Dual
            DRAM Frequency    665.1 MHz
            CAS# Latency (CL)    9 clocks
            RAS# to CAS# Delay (tRCD)    9 clocks
            RAS# Precharge (tRP)    9 clocks
            Cycle Time (tRAS)    24 clocks
            Command Rate (CR)    1T
        Physical Memory
            Memory Usage    56 %
            Total Physical    7.94 GB
            Available Physical    3.45 GB
            Total Virtual    16 GB
            Available Virtual    9.97 GB
        SPD
            Number Of SPD Modules    2
                Slot #1
                Slot #2
https://linustechtips.com/topic/908956-help-on-ram-upgrade/
RAM
        Memory slots
            Used memory slots    2
            Free memory slots    0
        Memory
            Type    DDR3
            Size    8192 MBytes
            Channels #    Dual
        Physical Memory
            Memory Usage    56 %
            Total Virtual    16 GB
        SPD
                Slot #1
                Slot #2
Looking at your output here, you have only 2 RAM slots and both are used already... you would need to buy a new 2x8gb kit to get 16gb.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/908956-help-on-ram-upgrade/#findComment-11169258
