So I downloaded PUBG mobile yesterday and it was working fine. I then tried playing on the train to school but there were connection issues (assumed it was server problems) but as soon as I connected to WiFi it started working. The game never works with my mobile data
CPU - AMD Ryzen 5 1600Motherboard - Asus Strix B350-F GAMING, RAM -  Corsair Vengeance RGB 16GB (2x8GB) 3000Mhz CL15, GPU - Asus Strix GTX 1070Ti, Case - Phanteks Eclipse P400S, Storage - Crucial BX300 240GB + Seagate Barracuda 2TB 3.5", PSU - Corsair CS650M, OS- Win10 Pro
https://linustechtips.com/topic/908487-pubg-4g-help/
4 minutes ago, Konrad Kwasniewski said:
Might be a weak connection, on a train you move quickly so cell signal will fluctuate a lot.
Happens when I'm standing still with 4 bars of 4G too though. Also, I forgot to mention but I have a Huawei P9 running Android 7. I can't even get into the login screen with a 4G connection
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164598
Weird, I tried this game on my Moto Z and with 2 bars of LTE it worked fine, maybe try checking the games settings or permissions.
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164617
It has full permissions and I'll check the in-game settings when I get home shortly
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164631
Nothing in the in-game settings about connection type, mobile data, etc.
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164657
Well, I saw many people complain on steam forums, and I am not surprised honestly. There is no concise answer, and it's bluehole so, so in the first weeks issues are inevitable.
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164666
In my settings, it shows that PUBG has used 2MB of mobile data so maybe it's the game itself and not my phone idk
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164701
Update: Using a DNS changer fixes it
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11164785
10 hours ago, yil0x said:
By any chance, can you tell me where the DNS changer is or like where you got it? Cause I have the same problem you had of it not working. Where is the DNS changer?
https://play.google.com/store/apps/details?id=com.frostnerd.dnschanger
Here's the one I use. If you can't use a dns changer for whatever reason then apparently a VPN will work too. The only problem with a VPN is the higher ping
https://linustechtips.com/topic/908487-pubg-4g-help/#findComment-11166984
