some kind of adhesive would work best. worst case scenario you'd have to re-paint the wall afte removing the panels.
5 minutes ago, HarryNyquist said:
I assume, being foam, they aren't very heavy. Could try 3M Command adhesive strips.
Ya, I've seen that it's been done with command strips and velcro so the panels can be rearranged. Thanks will for sure look into this
