confused idk is psu or mobo problem
PSP.
Hello guys
i should explaining with videos and pics pls watch
problem start with bios black screen . i uploaded 2 videos to asking about
1
2
ok almsot will say its mobo problem and bios ( bios updated ) same problem
next few days i turn my pc on ( no signal )
this video
dont see the video if you not want i do it for stupid Asus support ( nothing )
here gpu not working i used HDMI and DVI
i went to store and they plug them gpu working fine . my GPU not work with other PC`s
https://ibb.co/nqwuSx
https://ibb.co/cpr5Zc
https://ibb.co/eJXZSx
i contact amazon they replacement my gpu i love them
but the black screen still . now with only restart
( windows run fine ) but bios noooooo
i dont have idea did psu burned my video card ?
( psu still work )
or mobo burned my video card ?
now basiclly why i have bios black screen is bc psu or mobo
TELL ME PLEASE i will buy TODAY
I do not know the key to success, but the key to failure is trying to please everyone
Well I can tell you are not a native speaker, neither am I :-).
I had a hard time to get behind what you want to know.
So, to sum this up:
1. You get black screens out of nowhere
2. Your GPU was changed to a new one
3. Your PC was in a local PC store for diagnosing the problem
4. You can't enter the bios because it only shows a black screen
That all correct?
So, to sum this up:
That all correct?
only with bios screen like videos ( old card is dead ) with new card same problem
i worry about mobo or psu burn new card
also old card i was have black screen in game when i use ( Fullscreen mode )
displaying should wait 2 min
new card is cool but bios black screen still not fixed
2- Your GPU was changed to a new one
yes new and old ( bios not fixed )
Yes like maybe ram not work like that but we knew card  is dead
yes exactly with old card + new card
But note windows run fine
sometimes i pressing F2 to enter bios black screen holding windows not running i`m sure i was in bios but not displaying
with HDMI or DVI
i reset bios by COMS  and removed battery not fixed
i didnt  OC anything
 problem bc mobo or psu ?
does your cpu have an igpu? if so try to remove the dedicated GPU and connect your monitor to the boards video-port and see if you can enter the bios that way.
No i have ryzen not have igpu
i didnt have idea Black screen coz motherboard or power supply ?
