Let me start out with Specs "I know the GPU is a strange choice"
I5-7600k "Stock Frequency ATM"
ASUS Z-270i
16Gb Corsair DDR4 3000Mhz
GTX 770 Reference Edition
600w EVGA Power Supply
Corsair H100i v2
Phanteks Enthoo Evolv Shift X
Now. The problem... My pc will hang on boot (Crash) occasionally... probably one in 5 times. and needs to be force shutdown to be start back up.
What i have tried:
Dis-assembling and Re-Assembling the whole thing (4 times)
updating the bios
reinstalling windows on  3 separate drives
cleaning out every slot on the board
replacing SATA cables
Using Linux
Using Windows 7
Using Windows 10 Pro
Updating Firmware
Running fur-mark to test GPU stability (fine)
Running Cinnebench to test CPU Stability (fine)
Removing Overclock
Removing and Cleaning RAM contacts
Things that "Seem to work"
Using a different GPU
switching to on-board Graphics
Installing my GPU into another PC (it worked fine)
The crashes only occur when handing off control of the PC from the bios to the OS, It will show the windows logo, and 3-5 of the dots on the loading circle frozen in place.
The Crash does NOT occur when using these parts in a different PC (except CPU, I didn't test that)
The Crashes started when I moved my hardware from my NZXT manta to the Shift X.
Please, if any of you have some godly knowledge of these sorts of things please lend me some help
https://linustechtips.com/topic/906955-the-final-problem/
