Gaming display - please help!
Hi I hope you can help me as this monitor shopping is doing my head in. I want the best monitor for my money for gaming. My budget is around £300 give or take £30.
I've been looking at all sorts from 120Hz BenQ to normal 60Hz monitors and really cannot decide. One of my main musts is I would prefer a 27" monitor. In fact I may buy two matching monitors if I can ever decide which to buy.
Please help, I want good quality and don't want to be disappointed when turning it on.
Thank you. I'll be playing all sorts of games from MMO to FPS.
AMD FX8350 8-Core 4.6GHz///Corsair H80i Push/Pull///ASUS Crosshair V Formula-Z///8GB Corsair Vengeance Pro Series///MSi R9 290 4GB GDDR5///NZXT H2 Silent Mid Tower///Corsair AX860i///Samsung 840 120GB///WD Blue 1TB
https://linustechtips.com/topic/90646-gaming-display-please-help/
Budget?
Buy 120hz. Sure IPS will look pretty but the smoothness of 120hz will not only look great but it also will give you an advantage over others with 60hz.
The ASUS VG248QE is 144 hz and also supports the G-Sync upgrade kit so my recommendation goes there.
"If you do not take your failures seriously you will continue to fail"
Anything up to about £300
You need to quote a post or tag a member or else they won't get a notification you replied to them.
http://uk.pcpartpicker.com/part/lg-monitor-27ea33v
[ quote name=WoodenMarker" post="1224776" timestamp="1387483458]You need to quote a post or tag a member or else they won't get a notification you replied to them.
Oh sorry I am on a phone and only just worked out how to reply/quote you.
Thanks
Thank you I do like the look of this monitor.
