Case cooling feedback
Solved by WoodenMarker,
The front and top fans should be intake.
I'm not sure if a 92mm fan would fit in front of the hdd cage. It's best to measure first if you haven't already. My guess is that 80mm's would fit better.
The rear doesn't have any case fan mounts. If you want to mount smaller fans, you might need to do some modding. If that's the case, you should remove the mesh since it's going to obstruct what little airflow you're getting. That being said, it might make more sense just to leave that spot unoccupied.
