Hey guys, I finally got around to building today. I'm a first time builder but I know what I'm doing. I was having a bit of trouble mounting the motherboard and I touched it a few times when putting screws in the mounts. I'm also having a nightmare with the 24 pin and I don't know if I'm touching the case enough. Amazon haven't delivered the CPU yet so I can't even see if everything is ok. Sorry for the sloppy post but just wanted to know if touching the mobo can damage it?
https://linustechtips.com/topic/90606-help-super-nervous/
Why would you think touching the mobo can damage it? I mean you did say you knew what you were doing and all...
But seriously unless you are ripping capacitors out or bending pins inside the socket you cant do a whole lot of damage other than static damage which is mildly uncommon anyway.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224263
as long as you didnt scratched the motherboard in anyway you should be ok. did you managed to bend any pins or knock out any electrical component or IC?
anyway i dont think you can break the motherboard by just touching it. but lets just wait and see until you get your CPU
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224265
@Whos_Dan
Hey,
Nah, it should be fine. As long as you properly grounded yourself before handling the components and no power was running through the board, it will be fine.
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224268
Relax and don't panic. Just don't jab a screwdriver into the pcb. That would be bad.
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224269
Well only if you have a bunch of static on you. And touching case will probably just transfer the shock to rest of your components anyway which happen to be touching parts of the case.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224270
it if you are staticly charged you can damage your mobo, not by just touching it...
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224272
You should have waited to build the thing until you had all of the parts.
Here is the order of which the parts go in:
Case is the start.
PSU goes in.
Now let's move to the motherboard *DO NOT PUT IN CASE, JUST PUT ON TOP OF BARE MOTHERBOARD BOX*
CPU
RAM
Motherboard goes in case now. *SCREW IT IN*
CPU Cooler
Hard Drives
SSDs
all power cables routed and plugged in
Graphics card
PCIe cables plugged in
DONE
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224277
I meant to say I thought I knew what I was doing, but I just don't want to ruin my first build. I have been waiting 2 weeks for Amazon to deliver the CPU and I finally got time to build tonight.
Thanks for the help guys, I may just close this thread, I seem to have angered a few people...
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224295
None of us are angry. Most of us are just sort of all chuckling a bit on the inside and trying to give advice without pulling too many jokes.
https://linustechtips.com/topic/90606-help-super-nervous/#findComment-1224571
