Soundbar on PC Help!
Solved by ItsTheDuckAgain,
you need a standard toslink cable like this one: https://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B00NH11H38
IF your PC got an appropriate outlet for it (which most modern PCs should have these days).
They look like this:
Edit:
Your Soundbar should have come with one of those cables:
Also if your PC doesn't have an optical outlet you can still use AUX, but first go for optical, will be the best option here.
