RAM is kinda slow, it can cause stuttering on Ryzen systems.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/905879-need-help-with-low-fps/#findComment-11138987
8 minutes ago, Dryader said:
That might be it probably a driver conflict I recommend installing DDU and running it in safe mode then installing the driver off of the Nvidia website.
Now I'm not sure what will happen because ur cpu isn't an apu you might have a black screen when you boot you might have to download the driver onto a usb I think you should probably do some research in case I'm wrong.
windows has basic display drivers built it, it will flicker during the uninstall process then be fine, might lower the res though, that about it.
https://linustechtips.com/topic/905879-need-help-with-low-fps/#findComment-11138988
30 minutes ago, reeceraum said:
I am getting low fps and drops on games like Rust, Fortnite, and overwatch.
"Low" is maybe too vague. It would be better if you report the actual numbers and the settings you use *it could be that perfectly correct frame rates seem "low" relative to your expectations, or it could be that you get 5 FPS because 4K ultra all-in AA).
https://linustechtips.com/topic/905879-need-help-with-low-fps/#findComment-11139017
On fortnite I get around 100-120 fps on high settings.
https://linustechtips.com/topic/905879-need-help-with-low-fps/#findComment-11139048
