What is D: System?
Go to solution Solved by Mira Yurizaki,
1. No.
2. It's likely the bootloader partition, so if you remove it, you can't boot into Windows until you run a utility to make a new one.
Typically system drives are files/folders reserved for re-installing everything should the master partition become corrupted (you find this most often on a name brand system, Dell for example) but some of the latest systems also use it to verify the OS is "real", so wiping it out makes a hash of everything, so best to just leave it alone.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/905548-what-is-d-system/#findComment-11135329
