Are you using a screwdriver to jump the pins?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/904862-build-in-process-help/#findComment-11129354
Ok. So first thing is take 1 stick of ram out. Try to turn it on. Could be ram. If that don’t work try the other stick. If that’s doesn’t work I’d suggest trying the paper clip method (http://www.silverstonetek.com/downloads/QA/PSU/PSU-Paper Clip-EN.pdf). If the fan spins up your PSU is fine. If it doesn’t that’ll answer your question. If the PSU works and ram works then I’d suggest taking out the video card and try to boot on integrated graphics. Check your Mobo for swollen capicator, and if that don’t work I’d look into a cpu replacement. I’m dealing with artifacting gpu and I thought I was dealing with an issue, new gpu and still issue so it should be fine xD.
https://linustechtips.com/topic/904862-build-in-process-help/#findComment-11129369
Best thing to do is narrow it down to which component is taking a shit and RMA it. My rule of thumb is if the conputer turns on and stays on, without crashing then just play the game. Best of luck. BTW I installed ram wrong once and conputer wouldn’t boot, so I’d  check that it’s in place.
https://linustechtips.com/topic/904862-build-in-process-help/#findComment-11129374
10 hours ago, Newbie 2 said:
Nope ?. How do you do that mate ? What am I doing wrong here ?
You have to jump the power button pins to start your PC outside of the case like Jamiec1130 said.
It's not supposed to turn on without doing that so you don't have a problem at all :)
Here's a gamers nexus video on what pins to jump:
https://linustechtips.com/topic/904862-build-in-process-help/#findComment-11130488
