Please grahics card technical help
Go to solution Solved by thelordofwarr,
What GPU do you have? Did you just occasionally tried resetting the CMOS? Maybe run FurMark for a while, it should get it to temperature. Did you check the Auto at the Fanspeed slider in Afterburner?
tbh I just think that it goes into zero fan mode, but Idk what GPU you have
Ok so i was messing with msi afterburner fan curves and stuff and when i disabled the custom fan curv on msi afterburner my grahics card dosent wanna turn its stuck at 0% (even when its at 67°C) it just wont turn on can i somehow reset it? i want it to spin like normal withought msi afterburner or anything like that i just dont wanna over relay on third party software my OCD is freaking killing me (not litteraly) i tried
1) uninstalling and reinstalling msi withought saved settings
2) clean installed the whole thing
3) new drivers
and problem still occurs the fans just wont spin unless i put a fan curv on msi afterburner plz help!
(ill give you access to my computer using teamviewer if u want)
Grahics Card: Gtx 1050 by gigabyte (windforce)
https://linustechtips.com/topic/904419-please-grahics-card-technical-help/
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
44 minutes ago, endermanac said:
gxt 1050 (gigabyte windforce)
Yeah the no fan mode is something nvidia introduced back in the gtx 900 series if I remember correctly. The fans turn off if there is little/no load as to reduce noise. I wouldnt worry too much about it, as gpu's can tolerate heat up to about 80c without much issue.
