Help!! Weak wifi signal!!!
Go to solution Solved by 330213759@qq.com,
It's probably not your connection, a way to fix this would be to get WIFI Extender:
http://www.netgear.com.au/home/products/wireless-range-extenders/
Which should increase your WIFI signal.
I am sooooo stupid, just found out that I have to plug in the moving antenna that Asus has as a special feature!!
So i finished building my rig and found out the wifi chip on my rampage black edition iv motherboard has a really really really low wifi signal. It barely picks up any wifi signal, is it broken, or can i fix this problem? Its 801.2ac pro wifi chip, I don't want to plug in another small cheap wifi card so I really want to fix it. Is there a possibility that the antenna is not concocted properly because there is a wire that is concocted from my haf x case to the top of the case (i don't know what it is used for). I loosened that wire to disconnect the top in order to install my cooler but i put it back after. How can i fix the weak signal problem?
https://linustechtips.com/topic/90390-help-weak-wifi-signal/
how far is your router away from this rig?
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/90390-help-weak-wifi-signal/#findComment-1221363
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/90390-help-weak-wifi-signal/#findComment-1221373
https://linustechtips.com/topic/90390-help-weak-wifi-signal/#findComment-1221391
Well.... I'm glad I helped.
:P
https://linustechtips.com/topic/90390-help-weak-wifi-signal/#findComment-1221404
