Just wondering... how long a length of hose could a typical watercooling grade pump drive? I know it'll depend on many things like what else is in the loop, but assume for now, CPU block, GPU block, say a 360 radiator (maybe more), I'm thinking of a stupid cooling idea which would potentially need 20-30m in total. Think in the old LTT house room watercooling project he used a pond pump, which is not out of the question...
https://linustechtips.com/topic/903689-pump-drive-capability/
well, a pump needs basically no power to push liquid horizontally, tough pushing liquid vertically is pretty difficult. what kind of tubing setup would you be looking at?
https://linustechtips.com/topic/903689-pump-drive-capability/#findComment-11118028
Early planning stages... not thought it through yet. There will not be a significant height change, but even horizontally there will be a load due to the momentum/friction of water.
Idea is to have an external (to house) cooling solution (possibly open loop), while having PC inside. My other hobby is fishkeeping so I might or might not have something I can reuse there, if i can find the right adapters to go between them. Another option might be PC loop to heat exchanger, exchanger to external loop. Potentially more work.
Even with pond pumps, I'm a bit concerned as they're generally optimised for high flow and might not like restrictions in PC watercooling setup.
https://linustechtips.com/topic/903689-pump-drive-capability/#findComment-11118042
Most pumps list the specs on what they can do. Regardless you’ll need more than one for some out of room solution.
https://linustechtips.com/topic/903689-pump-drive-capability/#findComment-11120475
Take a look at Martin's Flow Rate Estimator: http://martinsliquidlab.petrastech.com/MartinsFlowRateEstimator.html
Download the excel file. He has done some research on the subject and come up with a table calculator that takes in the account the characteristics of the pumps and various blocks, fittings, hoses etc. It's a bit old and does not include the latest blocks, but it's fun to play with to get some rough ideas.
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
https://linustechtips.com/topic/903689-pump-drive-capability/#findComment-11121352
