23 minutes ago, MultiBros said:
Okay, so I need an rgb controller that is aura sync compatible with at least 5 ports. Do those exist? Any suggestions?
You can use splitters on an RGB header for more devices but note the max amperage of the header as you do not want to overload it.
Akasa does make a power RGB splitter to allow for more devices that works via Aura sync.
http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Gaming&type_sub=RGB LED Lighting&model=AK-RLD-02
https://linustechtips.com/topic/903615-rgb-controller/#findComment-11117180
thanks, this is exactly what I was looking for.
https://linustechtips.com/topic/903615-rgb-controller/#findComment-11117186
