Hello LTT forums! I had this problem for about a year now and I think its time for me to end this once and for all. I have the MSI GT73VR 7RE TITAN from 2017 and I have no idea how to fix this problem. When I play PUBG, I get around 80 - 100 fps usually and one day it just stayed at 30 - 40 fps which was a really drastic difference. It is only fixable when my nvidia graphics driver is updated and I get my frames back. However, when I turn my laptop off, this process must go through again. I tried factory resetting my laptop and ddu but both didn't help. Please help a fellow gamer out because I don't want to waste 5 minutes to go through the process every time I turn laptop on.
Specs:
CPU: Intel i7 7700HQ (non-overclocked)
GPU: GTX 1070
ram: 16gb ddr4 2400
Screen: 120hz, 1080p, IPS, 5ms response time
https://linustechtips.com/topic/902590-low-fps/
-Check CPU&GPU temps, usage and clock speed. See whether got throttling or not
-Check 'high performance Nvidia processor' is selected in Nvidia Control Panel
-Is it plugged in?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/902590-low-fps/#findComment-11106707
MSI laptops have a utility called “Dragon Center”
If the above doesn’t work, see if there’s anything inside there which can explain the low FPS.
Your laptop should not have issues with games like PUBG despite the poor optimization. A GTX 1070 paired with the GT’s stock cooling system should not throttle if well-maintained.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/902590-low-fps/#findComment-11110307
