Cleaning radiators
Go to solution Solved by W-L,
39 minutes ago, Sn1gel_ said:
This is after 15 times.
Keep going you don’t need to use distilled water for cleaning only for a final few rinses. I usually rinse and shake my rads a good dozen times and do a power flush by hooking up to the tap for a good 10-20mins in both directions.
I have been cleaning out my radiators for the past little while. My 360 SE has been rinsed and shaken with hot distilled water 10+ times and gunc is still coming out. I have to start using normal water (with the intent of rinsing it like 2-3 times with distilled after) or else I am going to run out of distilled water. And this is only my first radiator, I also have a 360 XE.
Am I doing something wrong? Is this normal? I heard you should only need to clean it like 5 times.
https://linustechtips.com/topic/902034-cleaning-radiators/
Depends on how long your had it running adn what kind of fluid you were using before
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101566
From wich brand is it? Also that isn't normal
My Build Log:
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101588
Normally EKWB products are very good, maybe try googling it if anyone else had that problem, also maybe contact EKWB
My Build Log:
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101603
Those are just some parts from production, i would still contact the EKWB support and hear what they say, they manufacture them so they are the experts
My Build Log:
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101629
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101688
OK I will do that
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11101713
Second this. I've flushed brand new radiators by hooking them up to a water filter system to catch all of that, with water flowing through in order to push all of the gunk out. The fill, shake, pour method will more shift around the gunk than get it out since there isn't continuous flow pushing the gunk out of the radiator.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/902034-cleaning-radiators/#findComment-11102068
