Case swap !
Go to solution Solved by TheSLSAMG,
The Corsair C70 is great for this. The bulge in the side panel makes nicely for thick cables.
Hey guys, so my current case is a CM K350, which is a decent case, only problem is the cable managment space on it.
Im trying to look for a decent case, with a acrylic side panel and fairly good room for cable managment, for more or less 150-100$
Thanks in advance,
-Logic  :D
https://linustechtips.com/topic/90169-case-swap/
https://linustechtips.com/topic/90169-case-swap/#findComment-1218748
Also consider the NZXT Source 530, if you don't care about the military look.
You're and your are not the same. Neither are their, there, and they're. Defiantly and Definitely are definitely not the same. Definately and Rediculous are not words, and you should feel bad for misspelling them. If English is your first language, you don't have a learning disorder, and you get any of these wrong, you are making the entire forum slightly dumber by doing so. Please take the extra three seconds to type properly, and have a nice day.
https://linustechtips.com/topic/90169-case-swap/#findComment-1220932
