I just acquired a SuperMicro X7DBR-E 1u server fairly cheap.
The machine has from what I can tell:
Dual Xeon X5460
32GB DD2
LSI Raid Card.
I am really new to having a local server and setting up things like RAID, ETC.
Anyhow, I am wanting to install FreeNas to do some testing on this thing and when going to the bios, I can not select my USB stick. See photos. Also in the F11 boot menu, it is not showing.
I know the usb drive is good and will boot on other machines.
https://linustechtips.com/topic/901539-help-with-x7dbr-machine/
Just an update.
Got FreeNas to load from another machine and installed on a flash drive. Then I figured out that you needed to enable the USB HDD in the bios by first disabling another as these bios only allowed 8 total.
Machine has been running 24/7 for the past few days and seems to be running fine.
https://linustechtips.com/topic/901539-help-with-x7dbr-machine/#findComment-11112571
