Hi.
This is my first PC Gaming. So, I hope it goes well.
Please tell my if it is going to work. if not what should I do??.
Motherboard: MSI B350M Gaming PRO AM4 AMD B350 SATA 6Gb/s USB 3.1 HDMI Micro ATX AMD Motherboard .
CPU: Ryzen 7 1700x.
CPU cooler: MasterLiquid 120 All-in-one CPU Liquid Cooler with Dual Chamber Pump by Cooler. Master
Hard drive: Seagate FireCuda Gaming SSHD 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive ST1000DX002.
SSD: Kingston A400 2.5" 120GB SATA III TLC Internal Solid State Drive (SSD) SA400S37/120G.
RAM: G.SKILL Flare X Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) AMD X370 / B350 / A320 Memory (Desktop Memory) Model F4-2400C16D-32GFX.
Graphic Card: MSI GeForce GTX 1060 DirectX 12 GTX 1060 GAMING X 6G 6GB 192-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready ATX Video Card .
PSU: Seasonic FOCUS Plus Series SSR-550FX 550W 80+ Gold Intel ATX 12V Full Modular 120mm FDB Fan Compact 140 mm Size Power Supply .
Case: MasterBox Lite 3.1 mATX Case with DarkMirror Front Panel and External Customization options by Cooler Master.
also, can anyone tell me if PSU will fits my case???
https://linustechtips.com/topic/901385-my-first-build/
6 minutes ago, Azam-45 said:
Hi.
Motherboard : MSI (X370 Gaming Plus).
CPU : Ryzen 3 1300x.
CPU fan : CPU Cooler H60 .
GPU : Gigabyte Geforce GTX 1050 2GB.
RAM : Corsair Vengeance 8GB (2 x8 GB) DDR4 2400MHz.
Hard Drive : Seagate 1TB BarraCuda SATA 6Gb/s 32MB Cache 3.5-Inch.
SSD : Samsung 860 EVO 250GB M.2 SATA.
PSU : Corsair CS Series, CS850M, 850 Watt (850W), Semi Modular Power Supply, 80+ Gold Certified.
Fans : 2x Corsair Air Series AF120 LED Quiet. Corsair Air Series AF140 LED Quiet.
Cables : JBtek All Red Sleeved PWM Fan Splitter Cable 1 to 2 Converter, 2 Pack.
1. Different Mobo Not an x370 cause u wont need it. Go for a B350
2. Ur CPU: Please invest 15 Dollars more for 1400 or even more for 1600 you will be happier
3. get the 4GB version of the 1050 or a 1050ti
4.your PSU is very overkill for this setup. Get a decent 550 Watt from Corsair or bequiet
Should be it ;)
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
https://linustechtips.com/topic/901385-my-first-build/#findComment-11094684
Unnecessary for a Ryzen, its not gonna get that hot. The boxed cooler will do.
Also unnecessary, get an Asus B350.
Too much, get a cheaper one with like 450-500w.
Ditch the rgb fans, the expensive cooler, the overkill psu and the expensive mainboard and get a better graphics card instead. A GTX 1050 ti isn't that much more expensive but gets you better value for money.
Rather spend 30$ more and get a r5 1600. The r3 1300x isn't good value for money.
https://linustechtips.com/topic/901385-my-first-build/#findComment-11094859
Think you for advice.
But I want to ask a lot of questions  if you don’t mind.
1)About motherboard: can I use MSI b350 micro-ATX instead of asus?.
It is not a about “I am a fan of MSI motherboard”.
It is about I want to spend 100$ or less.
2)CPU: I am going to use ryzen 5 1600. So what cooler should I have ?.
3) Is it okay to use graphics card from MSI/Asus/..... to another company motherboard ?.
4) And last question: PSU should I get 500-650 Watts?.
I am sorry for all this question.
I have never done this before. So, I’m a pit worry.
Again Think you.
https://linustechtips.com/topic/901385-my-first-build/#findComment-11095088
