Its an armor card, theyre pretty terrible. On that note, are the fans turned up? Can you turn them up more? Case airflow? Is it throttling?
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093162
1 minute ago, Synawke said:
yeah we need to know more info like your fan curve, case, airflow setup
well fan curve is set to factory settings or default
idk about the airflow and the case is xigmatek smthn but ive never had issues as i said i owned a asus dual gtx 1060 and never saw those temps
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093183
48 minutes ago, SoreRaito said:
Get yourself MSI Afterburner and change the fan curve a bit to comfortable noise and temp level's.
After that it should be better.
If you don't know how to do it just google it and look at a video its easy done after that. =)
ive been adjusting it but my new settings wont apply idk y
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093338
oh and even with the new settings temps are still high
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093388
How much did you change the settings ?
How high are we talking ?
And did you watch a video about it ?
Its kinda long to explain in writing for me english isn't my main language.
This is a video i found usable and easy to follow.
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093399
i saw the video and did the exact same setup opened msi kombustor to test didnt notice a difference maybe like a 3c change
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093412
How much Fan speed did you set at what temps?
And if the temp is still to hot maybe set it to let's say 80% speed at 80C and if that is to loud try and reduce it by 5% steps and see how your temps are. Scratch that just checked the complete settings he has and its at 80% speed with 80C
i feel safe with temps of around 65-70c max on my GPU under full load.
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11093425
You have to make sure both the left side and the auto button to the right of the fan slider are highlighted for your custom fan curve to take effect.
Like this:
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11095044
Like this:
i did that but theres a yellow line in the fan curve settings that wont let my fans to stop working when gpu isnt under load idk how to remove that
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11095608
32 minutes ago, Proch said:
oh and 60c max under load
By under load do you mean in a stress test like 3dmark firestrike, timespy, or unigine heaven, superposition, etc?
Because that's what we mean by under load.
These put a 100% load on your GPU and that's how to find your max temp not just regular gaming.
Just making sure you know that :)
Anyways, I'm not sure about how your fan curve won't let you turn off the fans under a certain temp.
I've never experienced that with afterburner.
Maybe someone else can chime in...
Actually, if I were you, I'd start a new forum post asking that because it's an entirely different question and you'd likely get an answer a lot quicker :)
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11095736
yea i was testing the gpu using fire strike and msi kombustor but still temps are seriously high even with the updated fan curve
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11095758
Don't use kombustor.
It's way too aggressive for just gamers.
It's more meant for professional level stuff.
Firestrike is good though.
Stick with that one.
Though you should use Heaven 4.0 or superposition for longer term tests.
After you find your perfect overclock if you are overclocking, you need to do a 3 hour test in something like that to make sure it's stable.
60 degrees under max load is fantastic.
That's not high at all.
https://linustechtips.com/topic/901206-gtx-1060-overheating/#findComment-11095775
