I've got a GTX 980 that I bought second hand about 6 months ago. It runs fine, but I have it at about 85 percent fan speed, and it sounds like a jet engine and it still throttles at an 85 degree limit. It is an MSI reference design and I was wondering if removing the shroud and stock fan and attaching a couple of good case fans to the top would be a viable way of improving thermal, and therefore overclocking performance (As well as making it a bit quieter). Here is the best link to show the GPU (I don't think it was that popular); https://www.msi.com/Graphics-card/GTX-980-4GD5-V1
Thanks in advance
EDIT: this should probably be in GPU's but I don't know how to move it
https://linustechtips.com/topic/901147-modding-a-gpu-reference-cooler/
Thanks in advance
Ever seen a nzxt gpu bracket? Takes aio coolers
There are akso aftermaket GPU aircoolers like the Arctic Accelero Xtreme IV
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
But it will only fit if it has a refrence PCB
My Build Log:
You might be able to lower temps by simply removing the plastic shroud. I've read about a user that removed the clear window on a reference model 1080 Ti and lowered temps by 10C. I'm not sure if the lack of a shroud entirely will have negative effects or not, but it might be worth a try.
The shroud is there to help channel air for the blower. Without it, the blower won't work as well when it's equipped.
Removing the window on a 1080 Ti is slightly different that removing the entire shroud.
It would be. Might be hard to mount fans though.
