I very recently bought Dell's Inspiron 15 5577. And it is marvelous for a budget laptop, it ran GTA 5 at top settings and 60 FPS with no lag or rendering mistakes and used all the available 4 gigs of video memory. But when I tried to play Fortnite, it lagged, hung and sometimes objects didn't render at all (everything was on medium settings) and I even crippled the FPS to 30. I know it's not a internet related issue because the ping is always 10 to 15 ms. I would contact the Dell's system support but all my benchmarks are game related and their tech guy probably won't know what I'm talking about too!
As a side note, my pal consistently gets 60 fps on medium settings and he uses i3 5th gen with Radeon m330.
Specs : 8 GB RAM, i5 7300HQ, GTX 1050, 1TB HDD (no SSD).
I've tried overclocking but not too much because overclocking may void my warranty. Overclocking seemed to improve the situation by a very tiny margin, the visuals were cleaner but the lag was still noticeably present.
https://linustechtips.com/topic/900094-graphic-issue/
If GTA 5 ran at top settings easily at 60fps then the fortnite should atleast get mid 40s to 50s. So it's not a laptop problem. Fortnite along with PUBG had and maybe still have some issues, bugs etc. Have you tried any other games that use many resources? Other games than Fortnite.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/900094-graphic-issue/#findComment-11081884
Yes, Tomb Raider (2013) at ultimate settings, Batman Arkham series at all ultra settings and Skyrim in ultra high. Watch Dogs 2 runs at high settings at about 48 to 50 FPS. All these benchmarks are with no overclocking.
And if this is indeed a bug, why is it showing up only on my system? Lack of resources or just sheer bad luck?
https://linustechtips.com/topic/900094-graphic-issue/#findComment-11091506
I would say bad luck.
TO BE UPGRADED:
https://linustechtips.com/topic/900094-graphic-issue/#findComment-11092982
  • 1 month later...
