used pc parts
Go to solution Solved by Streetguru,
6 minutes ago, tejinder said:
600ish CAD i have all peripherals
Probably worth getting the 2400G over the $80 cheaper 2200G, can add an SSD later just partition the hard drive so only like 160GBs are for windows to make cloning easier
Motherboard may need a BIOS update
PCPartPicker part list: https://ca.pcpartpicker.com/list/jDMwP3
Price breakdown by merchant: https://ca.pcpartpicker.com/list/jDMwP3/by_merchant/
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($209.99 @ Memory Express)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($110.50 @ Vuugo)
Memory: ADATA - 8GB (2 x 4GB) DDR4-3200 Memory  ($102.99 @ PC-Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon Canada)
Case: Rosewill - SCM-01 MicroATX Mini Tower Case  ($24.99 @ Newegg Canada)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.00 @ Amazon Canada)
Total: $564.46
Generated by PCPartPicker 2018-02-25 00:11 EST-0500
is it worth 400CAD
3.40 gigahertz Intel Core i5-3570K Quad Core
Corsair H60 high-performance Hydro CPU Cooler
Msi Z77A-G43 (MS-7758) 1.0 Motherboard
16 GB DDR3 - 1600 CL9 240 (4x4GB), Kingston Hyper
2TB Seagate Barracuda 7200RPM SATA3 64MB
Zahlman ATX mid tower Z11 Case
PSU Corsair TX 750
Disk reader/Burner TSSTcorp
TP-Link N900 Wireless Dual Band PCI Express Adapter capable of 5G networks
https://linustechtips.com/topic/899971-used-pc-parts/
I don't see a GPU there? What do you need it for?
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11080893
1 minute ago, tejinder said:
gaming , i m planning to buy one
Buy a Ryzen APU system then unless you already have a GPU or know where you can get a cheap decent GPU, because retail GPUs are pretty much not avalible outside of the GT 1030, which would give you the same performance as the Ryzen APU, but cause you to not be able to upgrade.
What's your total budget for a system? Do you need a monitor?
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11080899
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11080903
21 minutes ago, tejinder said:
is it worth 400CAD
PSU Corsair TX 750
Refurbished: Lenovo Desktop Computer ThinkCentre M83 Intel Core i5 4th Gen 4570 (3.20 GHz) 16 GB DDR3 1 TB HDD Intel HD Graphics 4600 Windows 10 Pro        $425CAD
$480 .15CAD - AMD Ryzen 2200G, 16GB, 1TB, Corsair CX450M
https://ca.pcpartpicker.com/list/WGHRBb
I see your budget is now $600, lemme see what I can do.
https://ca.pcpartpicker.com/list/CNWf7W
with AMD 2400G, CX550M psu, 8GB 3200,
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11080909
Total: $564.46
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11080913
The cheap rosewill case will likely be horrible though
https://linustechtips.com/topic/899971-used-pc-parts/#findComment-11081093
