I currently have a cooler master masterbox 5t
http://www.coolermaster.com/case/mid-tower/masterbox-5t/
It can hold 3x 120s or 2x 140s up front and 1 rear 120/140 and one top 120/140.
Currently I have 2 Corsair af 120s up front occupying the top two spots and the 2 included 120 case fans as exhaust.
I wold like to know if I should add one more 120 up front and change the exhaust fans to 140s.
Thanks!
https://linustechtips.com/topic/899145-question-about-case-fans/
You're fine :)
This video will help you with this question:
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
That should definitely be enough airflow for any current gen CPU + GPU system.
Main rig:
• Ryzen 3600X • X370 Killer SLI • 16GB Corsair LPX 3200Mhz • Strix 1070ti • Define R5 • SuperNova 750 G2 • Evo 1TB + X300 4TB •
Secondary rig:
• Acer prebuilt • Rzyen 1700X (upgraded) • OEM 1060 3GB • 256GB SSD + 1TB Seagate (upgraded) •
What are your specs and temps?
Is your system too noisy?
