Problems connecting to new router
Solved by ItsTheDuckAgain,
-1-
check if the lights are blinking when you plug in the cable on your RJ45 port. no lights = no electrical connect = no pewpew internet. Also check on the router side. (if one isde is blinking and the other is not: you are looking at the wrong cable :-) )
-2-
run this on command prompt:
ipconfig /release
ipconfig /flushdns
ipconfig /renew
-3-
remove the network card in your hardware manager and restart the system. Windows will install the drivers again.
-4-
lan cable plugged in the new router? maybe it's plugged into a dedicated uplink-port, depends on the model. anyway, try a different one.
-5-
restart everything
