Am I being really dumb and searching for completely the wrong thing but it seems impossible to find braided Sata power cables.
This is for my first build and I've got a 3.5" dri8ve for mass storage as well as a 2.5"SSD for my boot (couldn't afford an M.2 atm)  The cables that came with my PSU  are fine, but: a) are a bit too long, and b) have power connectors for 4 or five conncetors along their length and I only need 1 on each (SSD  mounted on the front HDD on the back).
What's the correct search phrase and does anyone have any specific suggestions? My build theme is black and white, so either colour is fine.
TIA
Simon
https://linustechtips.com/topic/898546-sata-power-cables/
TIA
Simon
If you are looking for full replacement cables for a modular PSU your going to need to get them ordered. Cable Mod has the option if you want to order a single cable and to customize the lengths as needed.
https://store.cablemod.com/configurator/
-Moved to Modding Section-
https://linustechtips.com/topic/898546-sata-power-cables/#findComment-11066657
