Old external harddrive missing power cable.
I will be posting a few pictures, however, the issue with the aforementioned HDD is that (I believe it is missing it's power cable). The cable that is missing is the round one. Am I able to purchase a new power cable, and is the HDD able to receive a new shell?
UPDATE: I think the simplest solution would just be to purchase a new enclosure like this one https://www.newegg.com/Product/Product.aspx?Item=N82E16817392075.
Update
https://linustechtips.com/topic/898519-old-external-harddrive-missing-power-cable/
Yeah normally you could transfer the hdd to a new enclosure no problem.
As for the replacement power adapter I found this:
Two posts:
https://arstechnica.com/civis/viewtopic.php?f=11&t=101760
http://forums.whirlpool.net.au/archive/1542923
An dead link:
http://store.antec.com/Product/accessory-spare_parts/mx-1-power-adapter/0-761345-30290-6.aspx
But there is nothing that really helps maybe some one can use these clues to find the replacement.
Two posts:
An dead link:
I think i'll just go with a new enclosure. Thank you for the help though!
Had the same thing happen on an old external drive (seems similar design but different brand). I got a different enclosure, and it has a normal round pin, plus easy to read voltage/amps and polarity sticker, should I loose/break the old cable, it's easy to buy a new one now!
